Can stock cats be welded onto an ORY?
you can make the holes big enough to install on the Y, the only downfall is the stock cats don't flow as well as high flow cats, but if money is tight, I say why not. By the way I've welded in stock cats, and it wasn't to hard, but I do prefere the aftermarket ones. Check out soundcats on Ebay they are 40 bucks and flow just as good as the best aftermarket performance ones.
