QTP HVMC guys inside please.
Just got my 1 3/4 HVMC headers and the collector after the merge is smaller than the opening in the y pipe. It is a really loose fit. Is this normal. I measured the collector and it isn't quite 3 inches (2 15/16ths) outside diameter and the y pipe is 3 1/16th. So I have an 1/8th of an inch to make up with the clamp. Maybe it is just smaller than I was expecting I guess. Any body else have the issue? Thanks.
John
John
wrencher
I like getting those band strap clamps. Those thing will seal real well. They are basically a 16 or so gage sheet metal. Tighten & it seals all the deformities between the pipes. You can get them at napa etc, they are mostly used on diesel trucks tractors etc.
Originally Posted by Durien
call them up and ask them....... mine fit just fine.. and yea the y is a tad bigger so that it fits over it..
