mac headers?
mac headers?
im thinking of getting mac long tube headers and im going to install them myself. do i have to lift the motor or will they go right on? and will i lose any ground clearence ? thanks.
For me it was the other way around, i pulled my passanger side threw the top and the drivers side threw the bottom. They are the easiest set i have put in so its not going to take you that long but if your used to putting headers in it should only take at most 2 hrs.
Originally Posted by MattIROC
They arent too bad to install. Passenger side goes in from under the car, driver side goes in on top of the engine bay with the removal of the steering rack arm.
Odd, mine was the opposite. The driver's side went in through the bottom with no problem. The passenger side dropped right in from the top after removing the valve cover.
