FS: BMR Bolt in Adjustable Torque Arm!!!!
LS1TECH Sponsor
I have a 2 month old BMR T/A. Its Black Powdercoat and it comes with a Polyurethane Bushing. They retail for 329 plus shipping. Looking to get 250 obo.... For any questions feel free to call 713 449 5992
BMR says:
Factory torque arms do a great job at robbing horsepower and torque and "dissolving" it into the chassis. Replace your weak, flexible stamped metal torque arm with a rigid BMR tubular version and put that power where it is supposed to be - the pavement! Made from MIG welded 1.25" x .120" tubing with heavy duty 1/4" mounting plates. Bolts directly in place of factory torque arm using all factory mounting locations. Requires no welding or drilling and clears all factory or aftermarket exhausts. The adjustable version comes equipped with a rear adjuster for adjusting pinion angle while the non-adjustable is preset at the optimal -2 degrees(in stock height applications). Both versions come with a new, low deflection polyurethane front mounting bushing.
BMR says:
