Rod bearing question
How hard is it to do rod bearings in the car. I really dont want to have to pull the motor no bearings have spun or anything just wanna freshen them up Can this be done.....
I'm working on getting main bearings out now. My next step will be to check the rod bearings. It's some what easy, just time consuming. You more or less have to drop the k-member to get the oil pan out. My current problem is trying to get the bolts from the side of the main bearings out, a regular 15mm socket won't fit.
