Manual Transmission - Weird Smell? What could it be?
nikeair042
08-27-2005, 11:15 PM
When I drive the car around town, easy shifting, perfect. But if I do a hard launch, I mean, barely spinning the tires, like a 2,000 rpm and slip out the clutch quickly, I drive away and get a weird smell. Even if I drive for a little while after that normaly, I can still smell it. I thought it was rubber burning, but after I parked it and got out, the tires didnt smell. Could it be the clutch? Is this normal? It's the stock clutch. Would could be causing this burning smell?
co.6z28
08-27-2005, 11:30 PM
ur upper lip? j/p man its the clutch
02 BLK WS6
08-28-2005, 01:02 AM
Maybe the power scares the sh!t out of you when you get on it. :barf:
It's the clutch slipping and getting hot enough to burn and stink. :)
nikeair042
08-28-2005, 01:29 PM
I mean, I do it once in a blue moon, but nothing to worry about or be concerned about? Does it hurt the car at all?
nikeair042
08-28-2005, 01:30 PM
Is it normal for it to do that? Or does that mean the clutch needs to be replaced?
2K2WS6TA
08-28-2005, 03:42 PM
No it's not normal, it means your clutch is getting ready to need replacing, it may last awhile longer if you don't drive too aggressively but it'll need replacing soon
02 BLK WS6
08-28-2005, 08:24 PM
Time for an upgrade.Stock clutches are weak.
MRZ28
08-28-2005, 09:08 PM
uummmmm........ ccluutchh!! :chug:
nikeair042
08-28-2005, 11:26 PM
what is the best clutch to upgrade to? I am not looking to spend a lot, and its a daily driver, so, best bang for the buck.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
