HELP!!! oil everywhere!!!!
Ok got cam installed everything done perfect, torqued to spec ect.... drove hour home= ok.....get home and theres like a oil residue all over my back bumper and Like 1 qt in my crankcase...look under the car and the underside is COATED in oil....doesnt start till about where the trans is...what the hell could have happened!!!???
Guess that means you dont need me to install that cam for you anymore.
Glad you let me know......
Good luck with the oil problem. Did you change the oil?
Maybe the filter isn't on correctly.
i Thought it was just burning a oil but a almost drained crankcase and underside coated in oil had me believe otherwise, especially since its before where my exhaust cuts off under the car
Also, if you were trying real hard to get the filter off, they have a tendency to tear a little bit. Maybe you have a 1" or so tear in the filter? That much oil loss with the vehicle still being able to run fine, makes me think its something petty, or stupid thats leaking.
yea it ran fine even while pulling into parking space (of course I could smell a light oil smell) but that we dripped a few drops on exhaust. I wiped off the bumper the 1st time then the 2nd time i saw oil there i knew something was up
