oil pressure
Old 08-29-2005, 12:40 PM
ruck98's Avatar
Default oil pressure
anyone have any problem with oil pressure after cam swap
Old 08-29-2005, 12:46 PM
blkZ28spt's Avatar
Search. Did you swap oil pumps or timing chains? If so, did you install a new oil pump pickup tube O-ring? Did you make sure that O-ring was not pinched?
Old 08-29-2005, 12:53 PM
777's Avatar
you prolly have a pinched o-ring. However, only if you changed the oil pumps. If not time to take it back apart and put in a new pump.
Old 08-29-2005, 01:03 PM
ruck98's Avatar
yes the o ring did have a slight pinch in it but we thought it might be ok and the oil pump is brand new and ported
Old 08-29-2005, 01:05 PM
blkZ28spt's Avatar
Tear it back down and replace the O-ring with a new one that does NOT get pinched. Problem should be solved.
Old 08-29-2005, 01:07 PM
777's Avatar
Indeed. O-rings/gaskets/seals should never be skimped on. Especially one as important as the oil pump.
ruck98's Avatar
thanks for the help guys i am on my way to gm right now to order one .
i sure do appreciate this
Old 08-29-2005, 01:08 PM
777's Avatar
They are like $5 how I do not know. Stupid GM
Old 08-29-2005, 01:12 PM
blkZ28spt's Avatar
They should have on on hand. FYI: It's called an oil pump pickup tube o-ring. At my dealer I slipped and simply called it an oil pump O-ring, which apparently made me an incomptetent moron kid (21 y.o.) who had no idea what he was tlaking about in the eyes of the employee behind the counter.
Old 08-29-2005, 01:25 PM
ruck98's Avatar
yeah that sounds like gm i will let you guys know what happnes but i will probaly have to order it this sucks
