double roller chain - squeeling fan belts?
Old 08-29-2005, 04:54 PM
robertbartsch's Avatar
Default double roller chain - squeeling fan belts?
I did a H/C about three years ago and used a double roller timing chain. Recently, I had some issues with throwing codes so I checked the rocker arms, timing chain, cam retainer, etc for busted hard parts.
Everything checked out OK.
When I re-assembled the car, my belts started to squeel. This was a problem I had a few years back too but it eventually went away.
Question: Is it possible the double roller is causing the crank pulleys to not align?
I tried a new crank shaft bolt this week end and torked it 37lbs + 140 degrees - no help with the squeel, however.
Old 08-29-2005, 06:23 PM
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
What year is your car?
Old 08-29-2005, 08:56 PM
LS1TECH Sponsor
mikey's Avatar
You probably got some coolant on the pulley(s).
Old 08-29-2005, 09:11 PM
Deamon2002's Avatar
Have you simply tried spraying the belts with belt dressing?
Old 08-30-2005, 04:55 AM
Brent@LPE's Avatar
a bar of soap will work well
