Should i run 0W-40 yr round??
Old 08-31-2005, 07:21 PM
GreekGator's Avatar
Default Should i run 0W-40 yr round??
i currently use M1 10W-30 but was thinking of switching to 0W-40. I live in Fl. and it gets pretty hot here. I've noticed during the summer my oil pressure will fluctuate a lot and sometimes go below 40 psi. Would it be ok to run 0W-40 yr round or should i just run it in the summer???TIA
Old 08-31-2005, 11:07 PM
GreekGator's Avatar
will any1 reply???
Old 08-31-2005, 11:42 PM
Ryan02SS's Avatar
I would run the M1 5W-40 Truck @ SUV oil instead of the 0W-40. It's more shear stable, has a stronger additive package and has a much higher HTHS (high temp high shear) number. $20 for 5 gal jug at Wallmart. Either grade will work fine in your climate.
Old 09-01-2005, 12:23 AM
racecar's Avatar
I tried 20-50 but it took too long to get oil pressure when I started the motor. Held great pressure when hot. 0-40 sounds good, it should be thin enough for start up and the 40 should have great protection when hot.
Old 09-01-2005, 05:38 AM
spy2520's Avatar
yeah i was thinking of switching too. but i live in MD, its really only hot half the year here. and it snows...usually. Sooner or later one of these oil guys is gonna say something.
Old 09-01-2005, 11:40 AM
GreekGator's Avatar
any1 else please???
Old 09-01-2005, 11:48 AM
Race your car!
JL ws-6's Avatar
I run the mobil 0-40.. never seen teh 5-40 oil in wally world... but hte 0-40 is always there. I've had no problems running it all year round.. I usually go out and start my car a coule times over the winter.. it sits in a carport, so it's outside temp wise. Last winter I started it after it was really cold.. the high temp for a 5 day period was like 10 degrees... started the car ( which turned over real slow at first ) and the oil pressure was there immediately.
Summer time, with the oil level in the middle of the operating range I'm at about 60 + psi when driving around, and at at least 40 at idle.. stokc 01 ls1 oil pump too.
Wear #'s came back good too when I had blackstone test it. I change the oil every 1000 miles.. which works out to about 3 times a year for me, once in the spring before the season, once in the middle of summer, and once at the end of the season, usually aorund the end of october. Way overkill on the change intervals.. blackstone said the oil had about 70% of it's life left LOL, but I'll keep it up anyway... never heard of anyone damaging an engine from changing the oil too much.
Old 09-01-2005, 11:50 AM
Fogle07's Avatar
i run german castrol 0w30. i live in georgia
Old 09-01-2005, 01:12 PM
GreekGator's Avatar
any1 else please. Please reply in response to my ? about M1 0W-40
Old 09-01-2005, 01:24 PM
Patman's Avatar
I agree, Mobil 1 5w40 is better than their 0w40.
Old 09-01-2005, 01:49 PM
GreekGator's Avatar
Thanks for answering Patman. Would it be ok to run that yr round???
Old 09-01-2005, 01:50 PM
lsx24's Avatar
5w40 is better than 0w40, and the reverse can be applied 0w40 is better than 5w30.
Old 09-01-2005, 01:57 PM
Patman's Avatar
Most definitely!
Old 09-01-2005, 03:10 PM
GreekGator's Avatar
thanks Patman and every1 else who responded!
Old 09-01-2005, 04:03 PM
Race your car!
JL ws-6's Avatar
Now I got to go find the 5-40 stuff. What does that bottle look lke.. what color cap? It's not one of those new ones that they have out with the advertised mileage on the bottle is it?
Old 09-01-2005, 04:10 PM
6 Second Club Moderator
LASTLS1's Avatar
I have no idea why you would run 0-w oil in Florida in the summer? You could run straight 30w! I run 20w-50 and get oil pressure right away. I see NO need for a 0w oil unless your in VERY cold temps! Good luck.
Old 09-01-2005, 04:36 PM
Sharpe's Avatar
Well, Hell!!! When did the oil god change his mind on this!?
Just kidding!
Old 09-01-2005, 09:27 PM
tirefryer's Avatar
I run Amsoil 5W40. That would be even better for you than the Mobile 1 5W40.
Old 09-02-2005, 03:51 AM
#3z-28's Avatar
Patman I live in Kentucky. It gets pretty cold here in the winter and pretty hot in the summer. Would it be safe to run German Castrol 0w30 year round? Thanks.
Old 09-02-2005, 04:47 AM
WS6WRX's Avatar
Yes, no prob w/ the Castrol 0-30, I run it here in Ga all year.
Quick Reply: Should i run 0W-40 yr round??
