Manual Transmission - So THAT's why my RAM started slipping...
Camaroholic
09-05-2005, 01:46 PM
My clutch spun back in May. Haven't had a chance to work on the car until today. Finally got the trans out. It's a RAM VDS/910. I love this clutch.
Apparently, my Eagle Crank is one of those units that leak out the center. Oh well. Easy fix I suppose. Hey Mike @ RAM, I'm finally about to send this thing in. :D
Also got a McLeod Bellhousing about 2 weeks ago. Seems to clear my Grot headers just fine. Heavy piece, though. Better safe than sorry. :thumb: Good replacement for my bellhousing blanket.
Formula 1
09-07-2005, 07:35 AM
Damn Redneck engine builder! :engarde:
Camaroholic
09-07-2005, 07:58 AM
I'm gonna buy 2 plugs, one for the crank, and one you can stick up your :moon:
:P
Formula 1
09-07-2005, 08:53 AM
If you do the work, I'm sure it will leak! :shakinass
Nine Ball
09-07-2005, 10:26 AM
I had a Lunati crank do the same thing on one of my 434ci setups. We had to use loctite on the flywheel bolts to keep them from seeping oil into the clutch again.
Country Boy
09-07-2005, 02:29 PM
How does a crank leak from the center or from the bolts?
Camaroholic
09-07-2005, 04:40 PM
LS1 cranks are hollow through the center. There's a 1" freeze plug (called a "crank oil gallery plug") in the center of the crank (stock crank also, though that one is just an ooch larger than 1", so it takes a $4 GM freeze plug to fit properly :eyes: ). If the plug isn't installed correctly (apparently mine wasn't - from Eagle, I looked at it after removing the pilot bearing, and it's just ever so slightly tilted to one side) - it will leak.
Or, if you try to use the 'old school' trick of packing behind the pilot bearing (pack with wet toilet paper or grease) to remove the pilot bearing, you'll find out about this freeze plug pretty quick as well. ;) They have been known to fall in to the motor if you do that.
And if the flywheel bolts are drilled all the way through (and not a blind hole), they can leak if you don't put Loctite on them. Though in my situation, it was pretty obvious that the crank plug was the culprit.
Better watch it Travis, or I'll get a plug for your mouth too. Though the City probably won't like me taking a manhole cover for your big mouth. ;)
Formula 1
09-07-2005, 07:25 PM
That's what I was going to use for your :moon:. I know about you and Clark! :)
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
