406ci?
Old 09-06-2005, 06:05 PM
cpss01's Avatar
Default 406ci?
LS1 is stock at 350ci but can someone have a 406? What does cubic inch measure anyway same with liters.
Old 09-06-2005, 06:07 PM
platinum's Avatar
Ls1 Is 347 Not 350.
Old 09-06-2005, 06:08 PM
platinum's Avatar
Never Heard Of 406 Heard 0f 408
Old 09-08-2005, 03:07 AM
Shinsetsu's Avatar
I thought it was a 346, 408 seems to be popular with the new style V8's. If you are wanting to figure up the CI of an engine its
bore X bore X stroke X .7854 X # of cylinders = C.I. for liters take the C.I and multiply it by 16.383 for a rough estimate.
Answer your question?
Old 09-09-2005, 12:52 PM
Super Hulk Smash
JakeFusion's Avatar
406 is for the old generation small blocks. It was a stroked 377 with 4.155" Bore and 3.75" Stroke.
And the LS1 is actually 345.9 cid.
Old 09-09-2005, 01:05 PM
BlueSix's Avatar
That'll give you cc's, not liters....for liters you should multiply by .016383, or do are shinsetsu said then divide by 1000.
Old 09-09-2005, 03:00 PM
Blue Hawk's Avatar
Visualize your piston at the top of the cylinder, then at the bottom. The volume of air between these these two extremes, multiplied by the number of cylinders, is what we call the "displacement" of an engine.
Take a stock LS1 for example, the bore (diameter of the piston) is 3.898" and the stroke (the lenght the piston travel from top of cylinder to bottom) is 3.622".
Applying the formula given by shinsetsu (bore x bore x stroke x 0.7854 x number of cylinders) : 3.898 x 3.898 x 3.622 x 0.7854 x 8 = 345.79 cubic inches, or 346ci.
To convert in liters, multiply by 0.016383 like BlueSix said : 345.79ci x 0.016383 = 5.665 liters, or 5.7L.
Old 09-10-2005, 01:35 AM
Shinsetsu's Avatar
whopps ya....just got off work and had some brain fade LOL
