LS1 vs LS6 heads w/ LPE GT2-3 cam
Old 09-07-2005, 02:12 PM
Pimpium57's Avatar
Default LS1 vs LS6 heads w/ LPE GT2-3 cam
I'm pretty set on using a GT2-3 cam in my SS for a dead silent sleeper (should I decide to even keep this car). I was considering just using my 241 heads and having them fully worked by TEA, etc, etc. I've also thought about forking over more cash for worked 243s, but would I really see any better gains with the 243s over the 241s as the GT2-3 is a baby cam?
Old 09-07-2005, 02:42 PM
JZ'sTA's Avatar
The LS6 will be better but is much more expensive. I would suggest a nie set of stage 1.5's You will gain some serious power and compression. Call TEA and comfirm but I feel this will be the best route.
Old 09-07-2005, 03:21 PM
Pimpium57's Avatar
Stg. 1.5 LS6's or 5.3L's? I never have any luck calling TEA.......
Old 09-07-2005, 06:44 PM
redtail2426's Avatar
i am putting the stock ls6 heads on my gt2-3 cammed ws6.I am gonna open them up just a little bit before they go on.I say go with something that will have the smaller port size 200-215 and it should make a nice combination.try to get some heads with the improved ls6 combustion chambers and higher compression.like stated before call around and see what you can find.
Old 09-08-2005, 12:03 PM
equandt's Avatar
I think LPE uses their GMPP LS6 heads with that cam.
If it was my money and I had to pick a set of heads for the GT2-3 I would be looking at a good set of stage 1 (5.7L) or 1.5 (5.3L) heads from TEA or PRC and I'd run as small of combustion chanber as possible, like 60-62 CC to get some nice compression.
If I were on a tight budget I'd buy a set of stock 243 heads off of ebay.
If I had unlimited funds I would stick a set of 205 AFR's on it. I believe the GT2-3 with some 205 AFR's would make an awsome street machine.
Good luck. Buy the best head your budget will allow.
Old 09-08-2005, 12:06 PM
JS
JS's Avatar
I agree the 205 would rock with that GT2/3 cam....
I'm going to run either the Dart or Edlebrock with my wimpy 214-222 559-566 cam
Old 09-08-2005, 01:41 PM
JZ'sTA's Avatar
I feel this is a very good post. I wouldn't run stock LS6 heads ever unless I competed in a stock head class. There are 2 many better options out now.
TEA stage 1, PP stage 2 would both kill a set of stock LS6 heads for about the same cost.
Old 09-08-2005, 04:25 PM
how high of compression can we run on the ls1 without crazzy ping or race gas ect.I thought it was somewhere around 10.5/1 someone fill me in here.And yeah those afr's would be sick.
Quick Reply: LS1 vs LS6 heads w/ LPE GT2-3 cam
