nitrous problem need help asap
Old 09-08-2005, 12:21 AM
quick99ws6's Avatar
Default nitrous problem need help asap
my nitrous recently started acting up. i have a 99 trans am ls1, with 05177 nos dry kit. the nitrous started coming on and off as the rpms climbed. so i made sure all my connections were good and the full throttle swith was working right. all was ok.....then i bypassed the fuel pressure saftey switch and bam, it worked. but my problem is, i dont want to always run without that switch hooked up. what is my problem??? im only running a 100 dry shot, my fuel system should be able to keep up with that, shouldnt it? fuel system is stock, but lots of guys run stock with a baby 100 dry shot. do these fuel pressure switches act up? im so confused please help......racing friday! thanks
Old 09-08-2005, 01:15 AM
Robert56's Avatar
Just out of adjustment. Pull the plug on the end and turn counter clockwise and this will lower set pressure. However, make sure you don't have a fueling issue that can't supply system, that can do this also.
Robert
Old 09-08-2005, 05:22 AM
XTrooper's Avatar
I would check the system with a fuel pressure gauge first before lowering the setting on the FPSS just to be on the safe side.
Old 09-11-2005, 04:13 PM
quick99ws6's Avatar
thanks everyone
Old 09-11-2005, 04:52 PM
Vax
Vax's Avatar
dont run it anymore until you figure out what the deal is, lack of fuel (running lean) is a good way to wreck that motor in a hurry.
