I will start modding my SS soon, Im starting with the suspension.
Well, I want to have the best traction and handling for when I start adding some HP
I have a bunch of questions so please be patient.
I guess I shoud make it clear that I will put on my car QTP headers with HVM and their Catted Y pipe. The car will also be lowered, Undecided with what, Springs or Coilovers. if springs, Most likely DMS. Maybe LG G2s. If I go coilovers, QA1s.So the parts have to clear.I shoud also make clear that my car will be a daily driver, Seeing alot of street Races, with about Drag strip duty twice a year.
-1st-
I been looking into companies like LG, BMR, Spohn, and UMI. So far I like UMI the most. Seems like their pieces are better made. I dont care about price, I rather have some great quality parts in my car. I love my car and well, I want the best I can afford.
What do you guys think ? Does it sound good to start modding the suspension first ??
What company do you guys like ??? Why ??
-2nd-
A-arms. Should I buy them adjustible or not ? What are the pros of Adjustibles ? Why do people use them ??? Shoud I get them Chrome Moly ?
-3rd-
Lower Control Arms. What should I buy ? Non Adjustibles, Adjustibles or Double Adjustibles ?? What are the differences ?? Shoud I get Chrome Moly ?
-4th-
Panhard bars... Same thing, What are the effects Adj. have over non-adj.?? and what about double adj.
-5th-
Torque Arms. Which one do you guys recommend me ????
-6th-
Sub Frames, I like the Kenny Double Diamonds, What do you guys think ? Should I go with bolt on style SFC or Weld ins ??? and Why ??
What SFC do you guys think are the best in terms of quality?
And do the Double Diamonds clear the QTPs and Catted Y ???
-7th-
What about sway bars ? Is it better to go Hollow or Solid ? I have seen both. And what size ??? I seen most vendors sell 32mm or 32.5 for the front But I seen that 1LE cars had 36mm ???....
Whats a good size ?? What do we have stock ? 30mm ??
And last question, What do you guys recommend, Should I go with Springs and shocks or a Coil Over setup ???
I like DMS springs, I also like LG G2s. I dont know what shocks I would get if I went with springs.
As far as a Coil Over, I like the QA1 Single Adj. that UMI sells. It says Firm Ride and great handling. Sounds good. I dont think they are expensive either.
So thats it for now. Im trying to get my head straight and decide on some quality parts for my car. Sorry if im asking too much
-1st-
-2nd-
-3rd-
-4th-
-5th-
-6th-
-7th-
IMO sorting the handling and chassis out on any car should be mandatory before adding hugh BHP.
Your best bet is to speak to the companies that make the parts, tell them what you want (be realistic) and see what they recommend.
As for adjustabel vs non-adjustable.
It depends. The non adjustable stuff will be setup as a ok average for everyday street use. The adjustable stuff will allow you to taylor your car to your exact needs. HOWEVER if you do not know what you are doing or are not propared to spend the hours of testing to get the correct setup you will be far worse off. As you'll probably end up with a bad setup.
Alternatively if you get adjustable stuff then leave it in the default settings (ie the same as non adjustable) why bother spending the extra money.
Adjustable will also run the risk of needing more checking as things can, do and will move over time. Non-adjustable is far less likely to encounter these issues.
If you where racing (sprint/circuit) then adjustable will allow alternate setups to match the conditions. But for daily street use it is not required, and besides are you going to spends hours setting you car up each week to counter different roads and weather conditions?
IMO - for the most part the non- adjustable is the better bet. If it can't be adjusted, you want worry about whether its right or not.
Originally Posted by ~ever~
-1st-
-2nd-
-3rd-
-4th-
-5th-
-6th-
-7th-
Wow...That's a lot of questions
