No Water flow
Old 09-09-2005, 08:08 PM
99SS-T's Avatar
Default No Water flow
I got a 99 camaroi ss and i have been having a problem with it overheating. So i checked everything like the pump the radiator for leaks and made sure that it is full of water. Everything seemed fine till i noticed that the hose that comes off the heads and goes through the TB aint flowing any water all. This all started after i changed the head on the car to 6.0 heads off a truck. Anyone have an idea as to why there wouldnt be any water coming through the heads like that? I have the TB bypassed so to make sure that there arent a issue with the hose that comes off the heads i disconnected the hose and tried to see if water came through the pipe on the head. Nada. Hope someone can come up with somethign to help me out here. Thanks
John
Old 09-09-2005, 11:57 PM
LS1TECH Sponsor
Steve - Race Eng's Avatar
Default coolant flow
Well, my best guess is the head gaskets are on backwards. The coolant transfer holes between block and heads are at the rear of the motor. If the gaskets are backwards, these holes will be blocked.
I put a post in a week ago with pictures of the gasket and transfer holes: https://ls1tech.com/forums/showpost....8&postcount=36
Steve
John
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
