M6: which driveshaft for 3.42 gear ratio?
Old 09-10-2005, 05:48 PM
tici's Avatar
Default M6: which driveshaft for 3.42 gear ratio?
I'm planning a transmission swap (A4 to M6).
Right now I have a steel driveshaft and a 2.73 rear end.
Sooner or later I'll have to change the rear end 'cause this ratio is way too long.
But what about the driveshaft? I was told that the steel one will vibrate a lot, this at least using a 3.73 rear end. Is it the same with the 3.42?
I think some of the 98 M6 were with the steel driveshaft... was it that bad?
Thanks - Stefano
Old 09-10-2005, 11:21 PM
2K2WS6TA's Avatar
The M6 with 3.42 used an aluminum driveshaft
Old 09-10-2005, 11:23 PM
DONAIMIAN's Avatar
My M6 has the OE steel driveshaft (my car went through the swap too) and its VERRY noticable after 110.
Old 09-11-2005, 11:38 PM
glennhl's Avatar
My M6 with 3.42's has the steel driveshaft. It does not vibrate at high speeds. You can balance a steel driveshaft as well as an aluminum one. It's just that some steel driveshafts got out without being balanced back in the mid 90's.
Old 09-12-2005, 12:45 AM
tici's Avatar
So you mean that a steel driveshaft can be as good as the aluminum one regarding vibrations?
Is it only a matter of balancing?
Quick Reply: M6: which driveshaft for 3.42 gear ratio?
