Oil Everywhere...Leak....
Old 09-10-2005, 05:51 PM
Z06-Dave's Avatar
Default Oil Everywhere...Leak....
After head/cam swap oil is leaking from somewhere but i don't know where.
It only seems to leak while driving but it is ALL OVER everything on the bottom of the car and all over the rear bumper. I can see what looks like to be a small drip from the crank seal behind the balancer, but i cant see how it could cause such a mess. Also the bottom of the timing cover looks ok too. Could a small leak like that wet down the entire car? There just seems to be too much oil to be from that small leak. Where else can i check? It does seem to be coming from the front of the motor and is all over the entire pan. There is none on my belts.
It is definitely coming from below the headers so it is not the heads or the valve covers. Is there a hose I might have missed somewhere?
Old 09-10-2005, 08:27 PM
pdd
pdd's Avatar
did you replace the cranks snout seal on the timing cover?
Old 09-10-2005, 08:51 PM
Z06-Dave's Avatar
No, I did not, it looks like it could be leaking slightly, but would that throw oil all over the bottom? It's everywhere! Oil pan, headers, rear wheel wells, rear bumper, etc...
Old 09-10-2005, 09:18 PM
Dave Carney's Avatar
The spinning balancer makes a pretty good throwing device.
It's your front crank seal, should be replaced every time the pulley is removed.
Old 09-11-2005, 08:14 AM
Z06-Dave's Avatar
Is there enough pressure in there to make it pour out like that?
Old 09-11-2005, 10:18 AM
No question.
Hopefully you have the timing cover at least reasonablly centered around the pulley hub.
One more thing, did you put a little rtv where the bottom corners of the timing cover seal at? That's called for in the Helms manual.
Old 09-11-2005, 11:49 AM
Z06-Dave's Avatar
Well, I though I put it on perfectly centered, I guess I didn't. I'm taking it apart now, I have the rack out. Hopefully I can get the pulley off with the radiator still in there. I'll stop by the dealer tomorrow to get a new seal. I did put RTV on the corners, I bet I put too much on and the cover is riding too high on the crank!
Can you provide the correct way to bolt the cover back on?
Old 09-12-2005, 08:01 PM
I used the jmx methodology where you try to make sure the bolt heads are where they were before by looking at the dirt/witness marks on the cover, then you don't tighten them down all the way until the crank pulley is on, that way it helps center the cover. Tighten the bottom timing cover bolts first.
Old 09-13-2005, 03:46 AM
vettenuts's Avatar
LS1howto also mentions putting RTV along the bottom edge of the timing cover, did you do that? I am getting ready to start mine, would like to hear what you find out so I don't make the same error.
Old 09-13-2005, 07:24 AM
Z06-Dave's Avatar
You definitely need to use RTV sealer on the bottom of the cover.
My timing cover is to clean to see where the bolts were.
I believe that I did not have the balancer on all the way but I'm changing my seal just in case. When I took off the crank bolt the end of the balancer did not meet then end of the crank snout. Can anyone confirm that they should be flush upon install? Mine was about 1/8 inch off. The accessories looked lined up though.
Doing a cam swap is fairly easy, I've just done it so many times, I didn't take my time, details, details, details...If you give yourself plenty of time, you wont have any issues. My first swap went without a hitch, it also took the longest.
Old 09-13-2005, 05:25 PM
vettenuts's Avatar
No, it should not be flush. According to the manual there is a recess of the crank snout to the hub of 0.096"-0.176".
Old 09-13-2005, 06:22 PM
mmmchickenboy's Avatar
gosh why couldnt GM spring for some dowels and make this 100x easier for eveyone...
