Which spark plugs for supercharge
My friend has Trans am LT1 and after he finished from building his engine with procharger so he wondering, which the best spark plugs for his engine?
Regards..
Regards..
I like the plain Copper Champions. I do a little work on rounding down the electrode with a file, maybe 5 minutes per plug, gap 'em at .035" and you're good to go.
Plus, they're cheap, so you can change them for $10, less on sale.
I'm running the RC9YC, which is 2 steps cooler than stock. No fouling or other drama.
I have 2 friends with SS Camaros, blown (1 vorthech, 1 ATI) and they both use the same type Champions.
Jim
Jim
I've heard these plug's only advantage is that they are more consistent over very high mileages, like 100,000+. I know their conductor is very small compared the the copper Champions. Why do the major blower companies recommend against the platinum and exotic metal plugs, at the same time they recommend adding an MSD ignition (or other CD)?
I may be missing something serious but I don't see why the iridium's rule in FI, and denso in particular for that matter. Any facts appreciated.
Jim
Jim
The BAD thing about platinum plugs is the tips fall off & get wedged in your combustion chamber. The good thing about Iridiums is they have a much better misfire rate. Does that justify $8-10 a plug? You be the judge. I'll be running TR6s.....
oOoly. looool good luck
Suspended Sponsor
Originally Posted by Vax
your choices are
denso iridium
denso iridium
denso iridium
hope this helps
seriously, they rule in FI apps, expensive per plug, but worth it.
denso iridium
denso iridium
denso iridium
hope this helps
I would be careful, we have seen noting but problems with the iridiums, they fail under severe loads and they also cause detonation problems, we have been able to give quite a bit more timing and gain SIGNIFICANT power in forced induction engines by going with the standard copper plugs like the RC9YC.
-Bryan
Originally Posted by 95zpro
NGK TR6 are a good plug to run for an NA setup!
If you are using any sort of power adder, I recommend a NON projected tip at least 2 steps colder like the Champion Rc9yc's mentioned.
I personally run NGK R5671A-8's in my motor NA and 9's for the juice.
Mike
your choices are
denso iridium
denso iridium
denso iridium
hope this helps
denso iridium
denso iridium
denso iridium
hope this helps
