Transgo Shift Kit Instruction help.
I pulled my transmission to clear up a problem with shifting.
I've done that but am unable to figure out the order of the springs/pistons in the accumalator.
The 3-4 piston was upside down and the yellow spring was against the case (upside down from the standard method).
It seems to make little sense this should be the case, but I believe that's the was the shift kit says to do it.
On the other side of the valve body plate, I believe there were two springs installed, but I can't remember if that was the case and I can't find my instructions.
Does anyone have a copy of the shift kit instructions on line? If not can anyone fax them?
I would really appreciate it.
Thanks!
Sam.
Thanks!
Sam.
For the fourth accumulator in the case put the yellow spring in the case, then the piston with the three tabs facing up toward the spring.
For the second accumulator put the orange spring toward the plate, then the piston with the three tabs facing up towards the plate, then the blue spring, the spring seat, then any spacers.
Sorry it took me so long to reply. I have the transmission back together and back in the car by using your first description. Hopefully it will work when I try it out tomorrow morning.
I have a fax machine and it might be nice to have a copy but I don't want to put you to any trouble.
I do have a question...
Reversing the location of the spring on the 3-4 accumulator (against the case) and placing the piston on top of it, would seem to defeat the 3-4 accumulator function altogether. I don't see how this functions at all.
It would seem to me that this is no different from simply removing the piston and spring and leaving it as an empty cavity...
Have I missed something?
Sam
Sam
re: accumulator ?
backward piston does disable accum- that is fine really not needed- 4th soft enough- but leave the piston out and then you mix 4th oil and accum pressure- wont work and will smoke unit in 2 miles of driving in what should be 4th- Craig- ps accumulators are cool they work so many different ways- will explain soon here willl take some time- harder to understand than torque converters- but I think I can help you to see it- Craig
Sam
Sam
I didn't fully understand the fourth accumulator arrangement either. They plug the fourth accumulator feed in their 700R4 kit so I took a plug out of one of those kits and blocked my fourth accum. feed hole to disable it.
Then I wondered why, if the feed hole was plugged, would you need to put the piston back in.
Originally Posted by jxaxsxoxn
Don't you have a printer? I could scan the pages.
Sam.
I scanned all the pages and they have a 100kb limit to upload them here, they are all around 128.
I can resize them if you still need them. let me know.
Regards,
Bert Veldhuizen
4th, 700, 700r4, accumulatir, accumulator, blocked, blue, instructions, kit, line, shift, spring, support, transgo, valve, woopudmsncom
