PCM Diagnostics & Tuning - stock cam ony tune for WOT
badmfkr
09-11-2005, 02:22 PM
my friend has a GM hotcam and his idel is real high around 900RPM after tune.
I only have LTs LS6 manifold ported TB so will the tuner leave stock idel and just tune for WOT?
Thanks
ninobrn99
09-11-2005, 05:34 PM
there shouldnt be any reason to mess with your idle if you have the stock cam. all he should be adjusting it your pt and wot a.f ratio. a good tuner will also touch up your ve a bit.
badmfkr
09-11-2005, 06:04 PM
sorry
I'm new just learning about tuning an LS1
what's pt? ve?
Thanks
ninobrn99
09-11-2005, 06:15 PM
part throttle, its where they tune your cruising speeds up to 4400 rpms. volumetric effeicency tables are ur air/fuel mixtures.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
