stall
Old 09-11-2005, 05:28 PM
darrell hoagland's Avatar
Question stall
what is a good stall for my 96 trans am with nitrous and lt4 hot cam kit thanks
Old 09-12-2005, 03:01 AM
Robert56's Avatar
About 3200, imo, or 3500, not much bigger unless you will be reving high and have some low gears.
Robert
Old 09-12-2005, 11:03 AM
Restricted User
CAT3's Avatar
Yep, go more than that and you better be able to spin it tight, as nitrous pushes past the normal TC rules. My old 3000 Yank used to flash at 3400 and shifted the same. I currently run a turbo spec'd Fuddle 3800 2.5str, of which I havent sprayed and may not since I am selling it. But the new one will be a 4000 2.4 or 2.5 STR and I am sure it will see 4600 or so out of the hole with 200 shots.
Old 09-12-2005, 10:58 PM
Need2gofaster's Avatar
unless you are runing slicks, spraying out of the hole isnt going to work very well. I love my 3800 Vig, but i cant spray as soon as i would like. Getting slicks and QA1's so i will let you know how that works!(If i dont shatter my 10 bolt 1st!)
