Cometic Question
Originally Posted by bigdsz
If the Cometics are not sprayed supposedly they are reusable, which I think some would question. Sprayed, not reusable.
Make sure you really clean the block and heads of the old gasket, I mean with a razor or you'll probably leak. Also make sure you put them on correctly. No sealant is needed or recommended.
