Tranny Question and problem
First of all, I have a 2001 camaro ss. 6-Speed. What tranny is in it. T56? Also, it seems to grind when I put it into 1st-3rd especially at higher RPMs. I can feel it through the shifter and in the clutch. Reverse is the same way. Once it is in gear, it is fine. No slippage felt. The hotter the car gets, the worse it is. We plulled the tranny last night and the throw out bearing looks fine. No apparent wear to anything. Clutch disk looks worn, but nothing majorly excessive. One possible cause is worn syncros???? I am hoping that it is just a worn clutch. Car has approx 60,000 miles on it. I am going to replace the stock clutch with a spec stage 3 but I want to find the problem first.I don't want to pull this tranny repeatedly if I don't have to. Any suggestions about shims or anything with the clutch would be helpful.
Any and all suggestions would be useful. Thanks
