Suspension & Brakes - subframe connectors
View Full Version : subframe connectors
formula001
09-12-2005, 11:10 AM
I am about ready to buy subframe connectors for my 01 formula any ideas on brands and what style?
00Z28SS
09-12-2005, 11:17 AM
It really depends on how your car will be driven/how much power you will be making. I think, for the money the Spohn tubular subframes are a great choice. They are strong, and will work well when racing with slicks.
Vax
09-12-2005, 11:19 AM
I recomend the 3 point SFC's
umi and KB make good 3 points
and umi is a sponsor -->
formula001
09-12-2005, 11:29 AM
My car is stock now but i plan on getin a 3500 stall and a few other light mods. and it will be a daily driver
00Z28SS
09-12-2005, 11:36 AM
For your application, there is no need for extra heavy duty and expensive connectors. Theoretically, their purpose is very simple: to connect the front and rear subframes and prevent the body from twisting and working loose; whether from normal driving or from torque-twisting launches. Even if you are not going to race the car, subframe connectors are a great idea to prevent chassis loosening, and keep the car's doors from not shutting right, t-tops not fitting, etc.
formula001
09-12-2005, 11:39 AM
So what do you think would be a relatively priced SFC for me
equandt
09-12-2005, 12:49 PM
SLP makes a nice set of sub frame connectors
My2ndls1
09-12-2005, 01:31 PM
I've got the BMR Tubular weld in's and am very happy with them. They make a big difference in how the car feels and handles! :)
DONAIMIAN
09-12-2005, 01:37 PM
I wish they stopped that along with the 1/4 pannel dimples, but unfortunatley they dont. They do make the car stiffer, but if I could do it all over again I woulda skipped the subframes and went straight for a 6 point.
silver30th
09-12-2005, 11:24 PM
ive noticed that BMR's seems to be cheaper comparing to company websites , about 30-40 dollars less than others. anyone know why this is?
Full-Force
09-12-2005, 11:50 PM
I myself just ordered a set of UMI boxed SFC's. They were only 139 bucks. I really wanted their 3 point SFC's. They are sweet. They were a little out of my price range right now.
I will be buying all of my chassis and suspension from UMI.
ifryrice
09-13-2005, 11:48 AM
I went with the BMR tubular's which is prolly what you should go with, because the boxed design you lose some ground clearance. BMR's shop is like a 20 minute drive from my dads house which i go to all the time. Im happy with mine.
UMI Performance
09-13-2005, 12:42 PM
We offer a large variety of options and I will be glad to help if needed.
http://www.umiperformance.com/SearchResult.aspx?CategoryID=42
Hope this helps!
Ryan
steveo346
09-15-2005, 01:43 PM
umi has soom good products i might go with them as well...i was thinking about bmr but umi looks kool
UMI Performance
09-15-2005, 03:19 PM
Thank you and I am glad to help if you have any questions.
Thanks,
Ryan
bad0211secws6
09-15-2005, 06:07 PM
Thanks,
Ryan
how much do your new 3 points weigh?
and your round connecters also?
UMI Performance
09-15-2005, 08:30 PM
The 3-Points weight in at 36 lbs a set while the 2-point tubulars are 24 lbs.
Hope that helps!
Ryan
SporkLover
09-15-2005, 10:26 PM
I have regular 2 point Boxed UMIs.... they look good and feel great
2K2WS6TA
09-15-2005, 10:38 PM
UMI 3 points, feels like they really stiffened up the car, in my case they stopped all the squeaks, and made the car feel more like one piece
ShowstoppaTransAm
09-16-2005, 11:12 AM
i have a 2001 convertible trans am. what do think would work best. price does not matter i'm just looking for the highest QUALITY!!! kenny brown, umi, bmr, global west, lg motorsports?
BMR Suspension
09-16-2005, 01:18 PM
We offer a subframe that reinforces the rear control arm box all the way around and has multiple weld points along the rocker panel http://www.bmrfabrication.com/sfc/conv.jpg :)
Lee Spicher
lee@bmrfabrication.com
NastyNate
09-16-2005, 01:58 PM
Ryan, why not make a chrome moly 3 point? Or is that already in the works?
blind527
09-24-2005, 05:57 PM
I may get the 3 point system from them on my 1997 Formula. Would you guys recommend bolt in or weld in? Will it interfere with putting a torque arm or any other mods or dropping the tranny for a TC install? How much of a difference in my E/T would I see with these since they add on a good amount of weight?
Bill Bowling
09-24-2005, 06:28 PM
I have the SLP Weld On connectors. They are great as a lift point.
Bill
:engarde:
N3V3RL8T
09-25-2005, 01:29 AM
I dont think ive ever seen subframes connectors for a convertible.
Foxxtron
09-25-2005, 02:31 AM
There are, if you're talking about aftermarket. I'm not too sure how the SLP "convertible style" ones work (e.g. supplement the OEM subframe connector, or replace it altogethor).
Genesis_26317
09-25-2005, 12:58 PM
I would love a chromoly weld-in diamond subframe connector set.
I would buy them right this second.
My SLP diamond connectors are HEAVY!!!!
Hell I wish they made 35mm chromoly sway bar and panhard bars as well... and them sell them through Summit since I have a credit card with them.
UMI Performance
09-25-2005, 01:34 PM
We attempted this but found that although the demand seemed high it wasn't when it actually came down to charging for it. Since Chrome Moly requires a different welding process (TIG) then mild steel it was very hard to come up with a 3-point that would work. We could do it but like I said I do not think the demand is big enough so we decided to only offer them in mild steel only.
Hope that helps!
Ryan
Genesis_26317
09-26-2005, 12:43 AM
Just how much would they cost?
Wouldn't it be possible to sell the arms with steel mounting plates with the chromoly connectors welded to it?
So that when you put them on it would be just like welding regular steel but with the bars being the nice stuff.
How much would they cost? Would they have been the same price as bolt-ons?
Wolfecraft sells chromoly subframe connectors for a reasonable price but I wanted diamonds because I am pretty much only going for looks...
cuz people always look under the car.
That and the stiffnesss will offset an airspring suspension's sloppy @ss handling.
Genesis_26317
09-26-2005, 12:44 AM
^ I hope.... :emb:
BMR Suspension
09-26-2005, 08:56 AM
Here are our convertible subframe connectors. http://www.bmrfabrication.com/sfc/conv-thumb.jpg
Thanks,
Jason/BMR
