Manual Transmission - Shimming a Spec Stage 2
View Full Version : Shimming a Spec Stage 2
keliente
09-12-2005, 05:20 PM
I received my stage 2 today, and I plan on installing it in a couple of weeks. I will be using the stock flywheel, which I'll have resurfaced.
The clutch came with a shim for the slave cylinder...do I need to use that? Will that make the pedal engage lower or higher off the floor?
oange ss
09-12-2005, 05:47 PM
i used mine
Griswold
09-12-2005, 07:32 PM
if you are using a resurfaced flywheel I would use the shim
618HAWK
09-12-2005, 10:52 PM
Use it!!!! On my 1st stg II left it out. ended up pulling the tranny out to install it. Will give you a good pedal engage height.
