IAT readings vs. actual outside air temps.
I was wondering how much hotter is the IAT reading than the actual air that is really going into the lid. I was thinking the radiator being directly under the lid must heat up that sensor and air around it alot. anyone actually compared real outside temps to the IAT reading?
Moderator
That chart seems to pertain to post-IAT warming of
the intake charge. However the IAT sensor's fidelity
is another matter. I have observed huge heat soak
in one configuration, my Blackwing lid with the IAT
mounted in the back corner registered huge offsets
from ambient (Walgreen's time/temperature sign)
after idle / parking and took minutes to come into
line. The combination of sensor and close-coupled
lid thermal mass, and a heat-exposed location, and
low, eddy-only airflow made for poor dynamic response
in the IAT. Many minutes for the heat-soaked IAT
to return to near-ambient readings.
Any thermal mass and cooling path will have an
associated thermal time-constant. Some are worse
than others.
Using the IAT in the 85mm MAF throat things are
much better now. A lid with the IAT in the neck, not
some low-flow backwater position, is better too.
than others.
More to the point, it might be interesting to compare IAT readings over time and at various speeds while outside air temperature remains constant.
For example, after cruising at - say 60 mph, come to a stop and idle and watch the IAT values rise until they peak, then do several quick blast up to 120 or so (on a closed course of course) and watch how long it takes the IAT to come down.
