Is it time to raise the B.S. flag?
Is it possible to attain 484rwhp from JUST the usual bolt ons(full exhaust, air lid), and heads and cam package? Someone told me he has 484rwhp from just all that and I think thats no matter how radical or big the heads may be, but then again I can wrong, thats why I ask.
Edit: I was told that he went with the SLP heads and cam package. I am not 100% sure about this though. And the car is a LS1 Camaro SS, 02 I think.
It's possible, but unlikely. There are some 346's doing over 500rwhp with heads/cam, but they are very radical cams.
edit: after i saw YOUR edit, I'm gonna call BS on that. I haven't seen great numbers from the SLP package, much less 485rwhp. He'd need something like a upper 230's - 240 duration cam with some good heads to make that.
Youd probably need EVERY SINGLE bolton imaginable right down to low voltage turn signals and high flow windshield washer fluid pump.
But really, youd probably need a perfectly matched intake/exhaust/heads/cam setup with a lot of luck. Or you could probably do a solid roller cam and hit that mark pretty easily.
Originally Posted by 777
SLP doesn't even estimate that much do they. We all know there numbers are very exagerated as well.
Most dealers/shop hp numbers are BS. When the numbers fall short, there are always excuses. Some just go way overboard with them..
Just a fact of life in the performance business!!
Originally Posted by freakynipples69
I knew this guy was big time. I actually raced him, and to make a long story short, I beat him, yet he claims "clutch problems". my ***.
BTW the only way he could make that much power with his set up is to be a full bolt on car + the tornado intake system
No, its not possible IMO, unless you go with a ridiculously huge solid roller cam and everything that goes with it.
I'm assuming thats a 5.7L motor? If its a 6.0L then its possible.
He got the 485hp package from SLP. I remember this package from a long *** time ago. It is no where near the 485 that they claim. I dont think it would even make 400rwhp. I dont even think SLP sells this package anymore.
Just ask him the specs on his cam we can tell you the rest.
This is the link to a 400hp set up from SLP. Max it could make is 330-350rwhp.
http://www.slponline.com/view_product.asp?P=28040
Originally Posted by Krazy98Z28
he could mean 485 flywheel horsepower
At 15% that would mean that it would have to make 415RWHP
If i remember right the specs on that cam are 218/220 112lsa. (I have not seen the specs in a long time so dont hold me to those specs.) But with all bolt on it could make it there in a 6 speed, 3.42 gears, AL drive shaft, and some light weight wheels.
