Please help* chitty,chitty,bang,bang!
Old 09-13-2005, 11:14 PM
SkankZilla's Avatar
Default Please help* chitty,chitty,bang,bang!
i've been chasing this 0300 random miss for a while now.
2000 C5 A4
Mods before skip are 3.42's, 2800 TC, LT's w/cats, Z06 Ti catback, vararam, and Predator. All mods installed w/ no issues for a few thousand miles.
Mod done just before skip is smooth coupler.
Mods since skip are MSD wires, NGK Ir plugs, velocity stack, and a mail order tune by Vette Docs
Started after swopping to a "smooth" coupler, went back to the original.
Had insuff switch in front o2's, replaced them.
IAT sensor failed, replaced it.
Replaced plugs, wires (made sure of clicks), fuel filter
Cleaned grounds
Just checked codes again P0113, P1111, P0300
Old 09-14-2005, 12:19 PM
WS6FirebirdTA00's Avatar
what is p0113 and 1111? a bad cat can cause random misfire
Old 09-14-2005, 02:52 PM
wait4me's Avatar
Did you do a crank posistion relearn on the computer? If you ever change the rotating mass, including a torque converter, then you need to have it done. The missfires may be fake, but the computer thinks they are real because of it having bad data.
Old 09-14-2005, 03:45 PM
robertbartsch's Avatar
i had po0300 issues recently..... no obvious casue.... replaced, cam sensor, crank sensor, plugs ...so far OK now..
