How much power are you putting through stock LS6 heads?
Title pretty much says it all......I'm wondering how much power the stock LS6 "243" heads are capable of supporting......and what other mods (ie which cam) is getting you there?
What about "mildly modded" 243 heads? And anybody responding to "mildy modded"....what exactly are those mods?
I'm thinking about getting a set of these heads......and my goal is 425rwhp on top of an LS1 block.....just wondering if the 243's are up to the job "stock" or almost stock or if I'd need to modify them somewhat drastically......if that's the case I might just go with AFR's instead.
Why waste your money on stock ls6 heads?
You will still need springs to support the cam, and your compression isn't the best IMO.
You would be better off with a stage 1.5 5.3 tea head, a stage 2 prc head, or even a PP stage 2 59cc head.
Either way you will make more power and spend very similar money.
But that's why I'm asking.....other than AFR's I don't really know what else is out there.
Do you have a link for more info on those heads you list? Know how much they cost? What vendors are good to buy them from????
Thanks in advance.....
The reason I'm considering "wasting" money on these heads is I can get a set for $850......which seems pretty cheap.
I got the heads for free. I work at a dealership and they threw away the whole engine which had a nice hole on the side. I took off the heads and as they say, the rest is history.
Originally Posted by Mighty Wings
I'm curious also, since I have a set of stock LS6 heads. I am undecided if I should have them ported and install big valves.
Take 850 and add a good spring kit.
These are just springs.
63-26918-16 Comp Cams 26918 Conical Spring (LS1/LS2 replacement) Suitable to .600 lift with more aggressive ramp-rate cams (Works with stock or Comp 772-16 Titanium Retainers) $159.99 Buy Wish
This is a whole kit which is typicially included when you buy ported heads.
63-26921-KIT Comp Cams 26921 Dual Spring Kit - Suitable to .650 lift with more aggressive ramp-rate cams - Kit includes valve springs, titanium retainers, spring seats, valve stem seals and instructions. $559.99 Buy Wish
Patroit has a stage 1 for 1000 bucks.
TEA has a stage 1 for 1000 as well.
PRC has their 5.3's for 1350.
TEA has a similar head for 1500 or so.
Patroit has a stage 2/stage 3 LS6 STYLE for under 1300 as well.
Now you can see why I refer to stock LS6 heads as a waste.
Now if you wanted a bad *** combo then LS6 castings can be superior after they are fully ported. Your now spending around 2300 dollars complete however including cores.
Check out TEA/PRC/PP/whoever in the sponsor area.
IMO the 5.3 TEAs are the best bang for the buck.
[QUOTE=X-ZZ4]Title pretty much says it all......I'm wondering how much power the stock LS6 "243" heads are capable of supporting......and what other mods (ie which cam) is getting you there?QUOTE]
So is anyone running stock LS6 Heads with a cam and bolt on's? Any horsepower/torque numbers?
415 rwhp/395 rwtq according to the boys @ A&A Corvettes.
451rwhp with stock heads and gaskets.
See sig for specs.
Steve
__________________
T-Rex Cam (242/248, 608/612, 110), Comp921 springs, Kooks 1 7/8" Hdrs, x-pipe/off-road pipe,Vararam, 4-tip Stingers, ASP UD Pulley, Dual Row Timing chain,TR55IX plugs, MSD Wires, 451 rwhp/396 tq NCM Member #23233
See sig for specs.
Steve
__________________
420 rwhp 396 rwtq.
fm13 cam
prc springs
lg's with offroad pipe
stock exhaust
trap intake
asp pulley
S3 TB
heads have never been off the car and it drives like stock (until you hammer it).
fm13 cam
prc springs
stock exhaust
trap intake
asp pulley
S3 TB
389rwhp. mods in sig.
__________________
01 Z06, Chrome OEM Z06 wheels, PRT Quad Ovals, Kirban shifter, Vararam, , TB bypass, 160 stat, GM hot wires, NGK TR55's, HP Tunersw/custom tune by RWTD, Bilsteins, GM Hotwires, NGK 55's, 3.73's,TPIS long tubes, Random tech cats/X pipe, MTI cam 224/224 581/581 114, ASP Pulley, Nitto DR's, DTE strut brace
Best 1/8 mi 7.75 @94.75 mph
__________________
401rwhp and 387tq (think) With iddy bitty Stealth II cam and LG headers with cats, minimal tuning.
So it looks like stock Z06 heads are up to the task of supporting around 425rwhp in some cases. The question is though, as shown by JZ's post, are they worth it - can you do better for the money? And I guess the answer is it depends how much do you have to spend on them. Now I've got a line on a very low mile set for just a couple hundred bucks....that is gonna be tough to turn away from. But for $850 as I said in my original post.....JZ is right.....that money plus a couple hundred would be much better spent on the options he layed out.
Thanks for all the info guys!
Thanks, for the info. I have 0 dollars invested in my set of heads , so I really dont have anything to lose. Yeah, for $850.00 dollars, there are better options out there.
Glad I was able to help.
I by no means think the 243 castings suck just feel there are better options for similar prices. Now if you get a set for free then thats hard to beat.
I just recieved a set of TEA stage 1 heads today.
I have some ported LS6 heads on the car now.
In 2 weeks when the tuner gets here I am going to dyno the LS6 heads, then pull them off and install the TEA stage 1's. Redyno the same day and get some good info.
Look for my post in a couple weeks.
My car stock LS6 heads 228/230 .571/.573 112+2 cam and all boltons (Tpis headers)420/399
G5X3 114 LG headerssame as above 427/400
G5X3 112 LG headersSame 435/405
G5X3 112 aluminum flywheel, Fast 90/90, EWP, 460/405
LS6 heads work-and for the price they are going for you can't go wrong.
I have an LS6 crate engine with LT's, lid, free mods, TSP 242/248 .625, 114 LSA with PRC springs/rods making 432rwhp/390 tq. I plan to have my heads redone next.
While I respect the AFR's, TEA's, etc... as they're great products, you can take a set of factory LS6 heads, have them p/p'd, valves, etc, and they'll flow very, very well, capable of supporting just about whatever you might want to throw at them.
