Is my car a dog, or do I have sticky tires?
Old 09-15-2005, 08:42 AM
fa18007's Avatar
Default Is my car a dog, or do I have sticky tires?
My car is an A4 w/ 2.73s. I tried to do a burnout yesterday for the first time to check if my posi was working. I turned TCS off, stomped on it from a stop and I just launched forward, no spin. I tried again with the shifter in 1st, same thing. Finnaly, I held the brake up to 2000 RPM and simultanioulsy let off and gave full throttle. I left maybe 7-8 feet of rubber (POSI works by the way). I was suprised how hard it was to break the tires loose. I stomped on it in a slow rolling turn and lit them up no problem and they spun all the way to 2nd. I have toyo proxies (245s) on my stock 16 X 8 rims. So I am wondering, is this normal, is my car a dog, do I have sticky tires, or is it just the gears. Thanks.
Old 09-15-2005, 12:24 PM
fasttagurl's Avatar
I think your car is working fine, unless I am out of it. I have an A4 w/ 2.73 gears, (not after today) and I had some Nitto drag radials on there with some ZR1 rims and the car would not hook-up real well. When I would take it to the track I would on the 1st run, but then after it would just spin and screw up my 60 foot times. Today I am getting 3.73s and some Hoosiers that are guaranteed to hook up. You may just need some new gears.
Old 09-15-2005, 04:43 PM
Coy
Coy's Avatar
2.73's are killing you. Your car is fine, my old A4 did the same thing.
Old 09-15-2005, 04:59 PM
Luna's Avatar
I have an A4 with 2.73s and I can't break traction for the life of me either, every once in a while they will spin a bit. Its a little sad a muscle car that can't break traction whenever the hell you feel like it. But at least you get better gas mielage
Old 09-15-2005, 06:43 PM
rocketman442's Avatar
Converter and gears mad a big difference on my LT1 caprice and those motors seem to have more bottom end power than a LS1. It should really wake up a LS1 f-bod
Old 09-15-2005, 07:52 PM
Jassick's Avatar
i got the 3.23's and i still have trouble, tried to break em loose about 3-4 times on the way home one night, i think once i got it to spin for about 5 feet. but i'm sure something is wrong with my car, the gas milage has dropped 2-3 in the last month. not sure y though
Old 09-15-2005, 08:44 PM
Wicked_Hugger99's Avatar
Get a line-lok...works great
Old 09-15-2005, 08:50 PM
catfish1512's Avatar
Wish I had that problem cant keep the rear planted with 275 kdw,s?
2001 a4 with just a lid.
Old 09-29-2005, 09:47 AM
magius231's Avatar
same thing here - A4 and 3.23's, won't break loose unless I really try (I can do it from a stall though). Also won't break loose from a roll but I would SWEAR I heard some spin going into 3rd@~75mph the other day
I think its a combination of low stall, low (numerically) gears, high torque peak, its set up for MPG, not for performance.
Old 09-29-2005, 11:39 AM
Ragtop 99's Avatar
Good news / bad news situation. if you don't spin off the line, then you can launch cleanly and fast. If you're spinning, you aint winning...
Bad news is maybe you could use more power down low. Get a 3000+ stall torque converter and you'll be faster and able to spin the tires.
Old 09-29-2005, 11:54 AM
SmokingWS6's Avatar
I recomend a good torque converter. You can match them up well with 2.73's.
It'll really make the car come alive. According to my logs I can't brake stall above 35% tps. Perhaps I need new rear brakes. lol
Old 09-29-2005, 01:19 PM
Ryan1985's Avatar
convert and gears and you can spin them all you want lol..
Old 09-29-2005, 01:55 PM
SteveC's Avatar
Location: Poway, Ca. where GOD and the sun always shines
Smile
The stock torque converter coupled to the 2.73 is the culprit, I am running a Y3000 coupled to 3.73's and do not experience what you are describing.
SteveC
Old 09-29-2005, 02:16 PM
Detroitmuscle's Avatar
I have heard of others having this "problem" before and its just the gearing. I myself have 3:23s and could spin em decently out of the hole stock and have toyos as well. Once the converter went in I cannot give anything near half throttle in first or full in second and not spin. What seems weird to me is that I never leave dark marks ever. Its always faint ones and its almost dissapointing.
Old 09-29-2005, 02:44 PM
AK's WS6's Avatar
The best way to find out if it's really a dog is to head to the nearest 1/4mi track and get yourself some time slips! My car with 3.23's doesn't really just light up the tires as it sits with pretty bald stock F1's but on a cool day I was able to get 2 12sec time slips out of 4 runs, so the whole spinning my tires thing really doesn't bother me.
Old 09-29-2005, 02:55 PM
dsz28's Avatar
Looks like you're putting money into show & not go. Want to spin 'em till the rubber falls off & be extremely fast? Look at my sig. I bought mine stock. Still looks stock but faster than any other car that has lined up with me.
Old 09-29-2005, 03:33 PM
formula001's Avatar
I have a stock a4 01 formula with 2.73 and i can spin them just fine from a stop or a low roll. I tried yesterday i felt the need to and from a stop i went for about 30 feet and hand a huge cloud of smoke behind me it felt great
Old 09-29-2005, 05:04 PM
s346k's Avatar
when my car had 273s in it i could spin for about 10' from a dead stop. one reason you may not be spinning when you try to powerbrake is because the brakes are holding the back tires. i experienced this when doing my first burnouts at the track with this car. i tried to spot them up and it just torqued, so i let off the brake a little and they immediately went up in smoke.
Old 09-29-2005, 07:59 PM
01ArcticSS's Avatar
You floor the gas, not the brakes......only use JUST enough brake to keep you from creeping forward....
Old 09-29-2005, 11:02 PM
Pontiacerator
RevGTO's Avatar
My car would barely break 'em loose with a stomp when I had 2.73's. 3.42's changed all that. Now, with the 3000/2.2 converter, I have the opposite problem.
