Traction Control logic
Does anyone know if the traction control on F-bodies can be set in the OFF position when the car is started rather than the default on position? Can the CAGS light be programed to light as a shift light?
Cags light can be reprogramed for a launch light, that's what I have done. You can see it with your periferial vision. You may have problems with using it as a shift light, though, and even a launch light. When I did a thread on this in tune section f-body guys were having problems, but I can't remember what it was. HP Tuners is how I did mine, many parameters to play with. Ther is a spot to turn on shift light, then I disabled all gears except 1st, if I remember correctly. I have it set at 3800rpm now, but am going to change it to 5500rpm. you might check tune sect and see if you can find the thread, I may have started it?
Robert
Robert
Originally Posted by TwoFast4Lv
Originally Posted by Rottluver
I have it and I love it. Take about 4 seconds to install and works like a charm for disabling the TCS......I have a Raptor shift light so I never bothered to program it in.
Until John gets the hang of driving/racing it might be best to leave the TC the way it is. When he's ready we'll change it over unless I've lost it and *I* need to keep it for awhile.
Naw, that'll never happen.
I like the launch light idea Robert. Thanks.
The SLP module sounds like a no brainer although installations sounds pretty complicated for me.
Originally Posted by GEARHED
It only takes about 2 seconds to push it to off...
Originally Posted by 99blancoSS
At first I noticed that I would have to turn if off evertime I started the car. But its not always like that. Sometimes when I start the car it remains turned off. Is there a memory ?
I was referring to the TC module. You take the switch out of the dash & plug the SLP module into the back of it....I don't have enough pedals in my car to know anything about CAGS.
Robert
Robert
I'd love to have a launch light as it's hard to watch tach, starter, tree and the blonde in the bleachers all at once!
I tried enabling the shift light yesterday with the controls and nothing lit up so I don't think on the F-bodies it relates the "shift light" with the cags light as it does in the corvettes
Robert
