What does this symbol mean in my Instrument Cluster?
Old 09-15-2005, 10:41 PM
SSDoubleK's Avatar
Question What does this symbol mean in my Instrument Cluster?
The Red Symbol in my Instrument Cluster is a picture I believe of a tank with like a little wavy river coming across the bottom of it with a arrow pointing down. Is this the low coolant light? I did put in a bigger cam, but got some customized computer tuning. Please advise. Thank you.
Old 09-15-2005, 11:05 PM
Phoenix 5.7's Avatar
look in your book to make sure, but that sounds like the low coolant lite. its possible that your sensor is bad if you actually are not low on coolant.
Old 09-15-2005, 11:08 PM
Blacker's Avatar
Coolant Level Low Sensor. Check your coolant level and top off, if needed. If the light is still illimunated, check the radiator cap and make sure it seals. Sometimes the filler neck can corrode and not allow the radiator to properly pressurize. If the light is still illuminated, remove the coolant sensor, it is below the filler neck. It is held in by a wire clamp. Clean the sensor with a q-tip and reinstall. If the light is still illumianted, replace the sensor. If you unplug the electrical connector, the light will go away if you don't want to replace the sensor.
Old 09-15-2005, 11:14 PM
SSDoubleK's Avatar
I did drain some of my coolant out, but felt I fiiled it right back to the top, ran the car down the road, I had let it sit for about a hour, rechecked coolant level and it was low. Thanx for all your help.
Old 09-17-2005, 08:11 PM
cgworth's Avatar
i bet it will tell you in the owners manual
