Sponsor Sales & Specials - Innovate Wide Band O2 Sale! LC-1 LM-1 XD-1
Time2Kill
09-17-2005, 02:32 AM
We're having a sale on the Innovate wideband O2 setups.The sale will end on Saturday, September 24th (one week). This is not a group purchase. Your kits will ship as soon as they are ordered as long as they are instock.
LM-1 Air/Fuel Ratio Meter (KIT) $324 + s/h
http://www.eadperformance.com/catalog/product_info.php?products_id=461
Includes: LM1, Bosch 5-wire Wideband 02 Sensor, Analog Output Cable, 10ft. Sensor Cable, 10ft. Power Cable (Cig), 6ft. Serial Cable for PC Connection, Bung/Plug Kit, Software CD, and Quick Start Guide.
LM-1 Kit with RPM Converter (LMA-2) $400 + s/h
http://www.eadperformance.com/catalog/product_info.php?products_id=463
Includes: LM1, RPM Converter (Aux Input #2), Bosch 5-wire Wideband 02 Sensor, Analog Output Cable, 10ft. Sensor Cable, 10ft. Power Cable (Cig), 6ft. Serial Cable for PC Connection, Bung/Plug Kit, Software CD, and Quick Start Guide
LM-1 Kit with AuxBox (LMA-3) $560 + s/h
http://www.eadperformance.com/catalog/product_info.php?products_id=462
Includes: LM1, AuxBox (LMA-3) Input Accessory, Bosch 5-wire Wideband 02 Sensor, Analog Output Cable, 10ft. Sensor Cable, 10ft. Power Cable (Cig), 6ft. Serial Cable for PC Connection, Bung/Plug Kit, Software CD, and Quick Start Guide
LC-1 wideband controller with 02 Sensor $180
http://www.eadperformance.com/catalog/product_info.php?products_id=460
XD-1 Standalone Gauge Kits (XD-1 Guage with LC-1 wideband kit) $360
http://www.eadperformance.com/catalog/index.php?cPath=41_62_124
XD-1 Programmable Digital Gauges $207 + shipping
All Accessories offered from Innovate are also 10% off. We have most of them on the website. If you dont see it, then ask, we should have it. Pretty much everything is in stock at the moment.
Thanks for checking
Tim @ EAD Performance
ROCNDAV
09-17-2005, 01:03 PM
Tim, I've been thinking of going with a MAFless system and HPTuners. I'm completely new to wideband. Which system would work with what Im putting together (in sig)
MeentSS02
09-17-2005, 01:27 PM
While I'm not Tim, I can tell you that since I have HPTuners with the EIO, I got the LC-1 wideband. It works great...I run MAFLess all the time. Can't beat the price either ;)
DWillTA
09-17-2005, 01:38 PM
Can you connect the LC-1 to any AFR gauge?
Thanks
NviouSS
09-17-2005, 01:47 PM
which one of the LM-1 kits works best with EFILive?
Time2Kill
09-17-2005, 02:59 PM
To the guys that have scanners/tuners (EFILive, HPTuners etc) you will want to get the LC-1 as its cheaper. The scanner should have an input for 0-5v which will work with the LC-1.
If you want to connect it to an AFR gauge, it needs to be 0-5v and it should work just fine.
ROCNDAV
09-18-2005, 11:57 AM
OK, another dumb question.
I take it I will have to weld another 02 bung onto the exhuast pipe for the LC1 to mount to. WHere does someone with tru duals mount this? If I go with Y pipe set up, then I take it I mount it after the Y merge?
Time2Kill
09-18-2005, 02:49 PM
You will need another O2 bung welded in (it does come with one), just weld it in right behind the driver side header. It does not need to read both banks. And it needs to be close to the header to get the best readings.
