Cutting out all timing
Old 09-18-2005, 11:15 AM
badaSS346's Avatar
Default Cutting out all timing
OK i got a weird question. inbetween shifts 2-3 (sometimes) ,3-4 (all the time), 4-5 (all the time), and 5-6 (all the time) my car drops all timing advance to 0'. I dont know why it does this but it causes the car to bog and makes downshifting difficult because it does the same downshifting thru all said gears. Any ideas what i have to adjust.
Old 09-18-2005, 11:47 AM
bmfcamaro's Avatar
check your knock retard. is it pulling the timing from you. then you have to mess with the retard tables. not sure exactly how but my car was pulling up to 8 degrees caused by false knock.
Old 09-18-2005, 01:47 PM
badaSS346's Avatar
There is 0 knock...Its only when you let off to shift up or down.
Old 09-18-2005, 05:17 PM
SikHabibBroCuz's Avatar
have you played with your DFCO settings?
i have mine set to come on when ever i take my foot of the gas and when its in DFCO mode it will retart your timing to what ever you set it to in the DFCO spark tables
Old 09-25-2005, 10:23 AM
badaSS346's Avatar
It is also cutting fuel i just learned.
