98 > 01 engine change
ok so i want to get a 98 camaro/transam. but i know that they first couple years with the ls1 engines had there own problems and what not . i want to transplant 2001 ls1 into the 98 engine bay . would i run into any difficulties with doing this?
there is no reason to do this.
Look at the numbers on both of my 98's.
The only reason you would need or want to go to a 99-02 motor is if you wanted to go bigger, like a 383, 402, 427 or whatever, because the 98' block cant be bored to much
the early ls1 engines had a problem with an oil passage in the back on the block. that once u started getting high in the HP it would start to affect the perfomance and possibly jack your motor up. it was in an article i read out of GM high performance or a chevy mag, dont remember which one it was. i'll have to go home and find the mag article. but i'll repost it tonight when i get home.
the 98-99 block issue you're referring to deals with oil returning to the oil pan from the top end of the motor. horsepower has nothing to do with it, engine speed (rpm) is the issue. the pre-00 blocks have 2 small holes in the back of the block for return, the 00+ have a much larger area. search a little and you might find a picture illistrating this. unless you plan on spinning 6700+, there is no need to change engines. if you're that upset over it, but an 01+.
