Western Members - Rear end shop in LA area?
Revelation222
09-18-2005, 01:32 PM
Anyone know the place that specializes in rear ends in the LA area. There was one talked about a few months ago that had great prices and a warranty on their work. If I remember correctly that is all that they work on. Of course other suggestions are welcome. Thanks
strokedls1
09-18-2005, 02:45 PM
I use Hoopers over in sun valley. Decent prices and all the do is rearends. You can yahoo their number. I usually deal with anthony over there.
Revelation222
09-18-2005, 04:16 PM
thanks, Ill check them out.
Phate
09-19-2005, 01:06 PM
I'd be careful of these guys, they assembled my Moser 9" when I first got it and left the stickers on the axles and never filled it with fluid (although they charged me for it).
I ended up having the rear re-done at 4 Wheel Specialties when my rear end siezed after about 20 minutes of driving.
Revelation222
09-19-2005, 01:16 PM
I guess I dont have to woory about it. I called them yesterday and noone spoke english. LOL
strokedls1
09-19-2005, 04:57 PM
They have done countless gears swaps for our 12 bolt rearends. They have also rebuilt a bunch of ten bolts for friends of mine. All of them have worked perfect. They even checked out my moser gear spacing and filled up the fluid for me for free. We assemble our own rearends minus gear adjustment so that is not an issue. 4 Wheel specialities were always aholes everytime I went to fill my nitrous bottle there.
SSpeedracer
09-20-2005, 01:36 PM
Toy Shop in Pomona, CA 909-620-5849 (Mike or Kendal)
dogboy
09-20-2005, 07:49 PM
J&S gears in Huntington Beach.
Revelation222
09-20-2005, 08:54 PM
I just talked to a Anthony at Hoopers. He said I couldnt use a 3 series carrier to swap the 2.73 out to the 3.73. He said I would need a 2 series to do it.
While this may be the optimal way of doing this swap a new carrier costs a butt load. Like $400 he stated. He also tried to sell me alot of other crap I didnt need as well.
Would a ring spacer (found one from Mr. gasket) be enough including whatever shims I need, or will I run into problems down the road? Anyone know or got any other shops that I can try?
Pendragon
09-21-2005, 01:22 AM
Give Transaction in Sun Valley a call. They did a great job on my stock rearend that the dealer could not fix right.
usa3776
09-23-2005, 02:54 PM
call Haddad Motorsports. they specialize in F-bods.
310-412-8032
haddadmotorsports.com
SP Motorsports
09-23-2005, 04:25 PM
the problem is you will snap the bolts off the ring gear with a spacer,with the power you are making.
Revelation222
09-26-2005, 03:46 PM
I pretty much figured as much. I just cant see spending near $800 to switch out some gears. I guess Im going to price some extra thick ring gears. It probably wont be as good as switching out the carrier, but it should be better than using the spacer.
travie319
09-26-2005, 03:53 PM
Red Bull Differentials.................in The City Of Bell Gardens!!!
Revelation222
09-26-2005, 03:55 PM
Could you PM me the number and address if you have it? Thanks.
Stone0fFire
09-26-2005, 04:14 PM
i used hoopers in sun valley
they did stock > eaton posi, rich 373, rp fluid, replace axle, solid spacer
one of the guys was kinda rude
two others guys were nice
they discounted for taking too long
theyre okay with me.
and i met GERS there.
they set up the moser 12 on his 98 SC n2o 427
and he said theyre great.
travie319
09-26-2005, 08:16 PM
pm sent
