Stock trans and transgo shift kit, need opinions on performance
Anybody put a transgo shift kit in a bone stock tranny. I have an 02 WS6. I want to put the kit in, can't reprogram right now. but would like to know what you did and how the results turned out. Thanks guys for any help.
Originally Posted by jxaxsxoxn
A bone stock trans is one that has nothing done to it. A shift kit would be one thing done to it to make it not bone stock.
It's like saying your engine is bone stock, then you put headers on it, thats the first mod to the engine, a shift kit would be the first mod to your trans.
I have a shift kit in my otherwise stock trans.
As far as that goes, a shift kit is not exactly a performance product. It's more for cars with large stalls and similarly sloppy shifts resulting from that. a shift kit firms them out a little, to make the shifts feel more like when the car was stock.
what spy2520 said. As for a shift kit and no programming,forget about it. DO NOT PUT THE KIT IN!!! You need programming to remove/lessen torque management, if you dont your car will fall on its face every time the trans shifts cause the computer will see it as an abuse mode and retard timing and fuel untill the speed of the car matches the throttle input(which takes several seconds after the shift)
I have an 02 WS6.
