WTF!!!!!! TCS turns on and off by it self! HELP!
just like it says, my TCS switch turns on and off by it self. The switch does not work. Any body had this problem before and knows what is wrong? It is very annoying when you can't turn it off when you need it to.
I had a problem the the TCS turning off when I had the MS3 in my car.
same things happenin to me,(only happens once every 2000 miles it seems) driving on the highway and the light comes on "tcs off" and the button doesnt work. i get to wherever im going shut her down then fire it back up and the lights off.
I had this problem on my Z......check the little rubber hose about 1.5" long right behind the throttle body that connects the PCV hose to the side of the intake manifold......it is very soft rubber and I had a hole in mine. It took a long time for me to ever throw a lean code, but I had an occasional ASR on then off by itself and a very rough idle. Sometimes I would start it and it would idle at about 1500, shut it off......start it, and it would idle normal......very strange.
