ATI Crankshaft Pin Kit
Old 09-19-2005, 11:51 AM
vettenuts's Avatar
Default ATI Crankshaft Pin Kit
Who has used this, and what speed did you run the drill for this operation? Did you use cutting oil?
Old 09-21-2005, 11:21 PM
b727pic's Avatar
I used a 3/8ths snap on air drill, just sprayed a little LPS 2 in the drill guide and SLOWLY applied pressure. went approx 1/3 the way removed cleaned debris more lube, repeat....repeat. Actually the process is very painless. the material is softer than you think!!!
I measured how deep I needed the hole to be, then marked the drill bit by wrapping electrical tape at the appropriate spot . worked like a champ!!
Old 09-22-2005, 12:36 AM
BOONE's Avatar
I did it literally exactly the same way. I went fairly slow in speed.
Old 09-22-2005, 03:34 AM
vettenuts's Avatar
I ended up doing it dry because ATI told me to. I also have a pin that is loose (slides through) in the crank.
Old 09-22-2005, 06:40 AM
BOONE's Avatar
If its loose they make a sleeve and retainer pin loctite, that may help.
Old 09-22-2005, 09:41 AM
b727pic's Avatar
My Pin had to be "tapped" into place, I used a little locktite, although its not needed the balancer bolt "retains" everything in place.
Sounds like you got it done.
good luck with the rest of the install.
Old 09-22-2005, 10:05 AM
vettenuts's Avatar
I ordered some oversized pins, 0.001 and 0.002. One of those should eliminate the slip.
