Fpss
Old 09-19-2005, 04:11 PM
sickss228's Avatar
Default Fpss
Can someone help me? I am going to buy a fpss but i need one that will cut off the nitrous if the fuel press drops below 58psi right? Where can I get one, or who has a part number so I buy the right one. I tried doing a search but came up with no solid info.Thanks
Old 09-19-2005, 04:24 PM
Matt@HSW's Avatar
Most FPSS are adjustable so you can set it where you want it to be. Adjustments are made via a allan key and twisting it left or right. Below is a link to our FPSS:
http://www.harrisspeedworks.com/shop/home.php?cat=318
Matt
Old 09-19-2005, 08:21 PM
LoWeLL216's Avatar
All the nitrous sponsors here sell them. Harrisspeedworks, Nitrous Outlet, Dynotune, etc.
Old 09-19-2005, 09:34 PM
1ScrudeDude's Avatar
Good choice on using one. Hopefully I install my NX kit this month, and I hope to get the FPSS dialed in.
Lot's of peeps had issues with them, but I am determined to get it functional.
Old 09-20-2005, 02:24 PM
Matt@HSW's Avatar
You're right, some people do have problems with them. 99% of the time it is due to not having them adjusted correctly.
Matt
Old 09-20-2005, 03:25 PM
sickss228's Avatar
How do you properly adjust them?
Old 09-20-2005, 05:57 PM
Yup good question, I know there's a lot of trial and error. Which is where many have given up (no patience?)
Old 09-20-2005, 06:35 PM
Matt@HSW's Avatar
Send me a PM with your email address and I'll send an instruction set.
Matt
Old 09-20-2005, 08:45 PM
LS1TECH Sponsor
DynotuneN2O's Avatar
We offer the Hobbs FPSS. http://www.dynotunenitrous.com/store...?idproduct=135
We test and calibrate every unit before it leaves our facility. They are pre set by us at 35 psi so you know where you are starting if you need to adjust it. We also provide complete instuctions as well as a chrome fitting and required connectors.
Dean
Old 09-20-2005, 09:15 PM
JoeyGC5's Avatar
Dean
I don't have the instruction sheet in front of me, but it's roughly 5psi per one 1/4 turn right??
