Fueling & Injection - injectors for 402CI
View Full Version : injectors for 402CI
robertbartsch
09-21-2005, 02:21 PM
Can you use 5.7 stock injectors? If no, what are my alternatives?
Thanks
robertbartsch
09-22-2005, 02:48 PM
I guess I will use the old injectors and hope for the best.
Bryan @ Speed Inc.
09-22-2005, 02:54 PM
no no no no... i'd get atleast the SVO 30# injectors. i'm running those on my 402.
robertbartsch
09-22-2005, 03:15 PM
...oh sh^t... more dough needed for this project....
Is it simple to tune for bigger squirts? LS1Edit - here....
Elite_Hot_Rod
09-22-2005, 04:47 PM
Are you planning on running a power adder on your 402? If so 30's probably won't be big enough.
robertbartsch
09-26-2005, 09:31 AM
where can I buy 30 SVO injectors for cheap?
DrkPhx
09-26-2005, 12:34 PM
I'm running the Delphi 42-lbs injectors on my 402 setup.
jhong321
09-26-2005, 04:04 PM
i was going to ues the stock injectors on my 402 H/C but i really think i would be pushing it. it would not be worth it to starve the motor that just cost $4000 + so you could save $300 bucks plus you will have to get it retuned when you find out you will need bigger injectors that is another $400 . i just got the 32# injectors. i hope that will be good enough.
