over boost
over boost
Any idea why my my car is over boosting. It is a front mount turbo. I had it running at 10 psi but today when I smashed the gas it ran up to 17 psi before I backed off. It has happened 3 times now tonight. Is it the wastegate maybe.
I hope you have a good bottom end! If you see the boost rising like that, I would back out of it until you get the problem corrected, as a 10 psi tune is going to be far from a 17 psi tune. Bob
I am running a eboost controller.I even tried unhooking it and letting it run just on the 7 pound spring no luck.I have been backing out now that I have noticed this problem. How can I check my wastegate to see if it is working?I know the bov is working it is a 50mm trial.The boost reference come off the turbo outlet is this the right place or what?
LS1TECH Sponsor
Pull the WG off. Pull the top cover off (becareful it will be spring loaded). Once you get it open take the spring off and see if the valve moves freely. Sounds like you have stuck wastegate.
Guys, he said he pulled the references off the WG. That means its solely working off spring pressure. If it doesn't open you have a stuck valve or stem.
Jose
Jose
