Stand alone fuel cell.
Old 09-21-2005, 09:13 PM
1999TransamWs6's Avatar
Default Stand alone fuel cell.
Was thinking about going with a 2 stage with a dry NOS5177 kit and a tnt kit but was thinking about getting a stand alone set up for the wet kit. Any ideas in what all is neaded. I have an idea but would like a list if possible to make shure im not leaving anything out. Also i know fuel is most important with a set-up like this so is an intank 255, 42# inj. and the stand alone with an aditional 255 sufficiant? Also it will be ran with 110 octane. Anyhelp/pics would be greatly appreciated.
Thanks
-Joe
Old 09-21-2005, 10:23 PM
Closed ex-Sponsor Account
NXRICKY's Avatar
2 255 Pumps are more than enough for most systems out there.. You might check with Nitrous Outlet standalones. I have seen alot of pics and he puts everying in there. I can not post any pics dial up sucks.
www.nitrousoutlet.com
Ricky
Old 09-21-2005, 11:31 PM
Elite_Hot_Rod's Avatar
If you don't buy the stand alone set up Nitro Dave sells you will need a fuel cell, fuel pressure regulator, fuel pump and fuel lines and fittings.
Old 09-21-2005, 11:54 PM
Somebody09's Avatar
Here's what I'll be getting (eventually) https://ls1tech.com/forums/nitrous-oxide/367170-nitro-daves-fuse-box-side-stand-alone-fuel-system-installed-pics.html
-somebody
Old 09-22-2005, 04:40 AM
thanks alot guys. You helped alot
Old 09-22-2005, 10:53 AM
Nitro Dave's Nitrous Outlet's Avatar
If I can help you in any way with one of our units please let me know.
Thanks
Dave
Old 09-22-2005, 07:40 PM
383LQ4SS's Avatar
Get one of Nitro Daves...trust me. It may sound like alot...but in the long run its gonna cost you close to that doing it yourself. I just finihsed about 90% of my stand alone today and I used a Jazz fuel cell and a stand alond pump/regulator combo. Those parts added up to about $350. Then I had to get lines, make lines, get fittings, figure out mounting and routing etc. Its a little more of a PITA than it first appears. Today I spent another $130 in misc. fittings
I have also installed one of Daves sytems.....and it could not have been easier. Highly recomend the prebuilt setup that just bolts in.
Old 09-24-2005, 02:23 AM
Eugenio_SS's Avatar
https://ls1tech.com/forums/nitrous-oxide/384506-look.html
Old 09-24-2005, 02:39 AM
red90cobra's Avatar
nitro dave is the way to go with this.
