Do you have to cut the hood for a Vortech aftercooled S/C??
Old 09-23-2005, 07:17 AM
BLk01SS's Avatar
Default Do you have to cut the hood for a Vortech aftercooled S/C??
Thinking about buying one for my Hugger car. Whats the normal boost level on a G-Trim. The guy told me it was 9lbs. Seemed high to me, will that be ok on a stock block?
Thanks in a advance =)
Old 09-23-2005, 08:20 AM
Got Me SOM's Avatar
For an SS yes you would have to notch out the hood.
your kit can make 9 lbs at probably 6500 or so but i wouldn't run it up there without valvesprings.
As long as your fuel tune is right your stock block should take it.
Old 09-23-2005, 09:37 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
That amount of boost will vary depending on cam, heads, headers, catback. You might not get to 9 psi. The less restriction the less psi.
Old 09-23-2005, 10:47 AM
Got Me SOM's Avatar
boost is dependent on rpm, 9 lbs should not be a problem.
he's on a stock engine.
Old 09-23-2005, 09:07 PM
TT-TECH Veteran
Inspector12's Avatar
Boost is a measurement of restriction. If you have head or a cam less restriction so you will see less boost on the gauge, but you are still moving the same amount of air just more efficiently etc... that is why it will depend on what you have done to your car. 100% stock yeah @8-9 lbs. Hope I gave you a little more info.
Jeff
Old 09-25-2005, 08:44 AM
EPP
EPP's Avatar
Why not go with an ATI ProCharger D-1SC? You will be able to make plenty of boost, you don't have to cut the hood, the weight of the added parts sits lower in the car for a lower center of gravity, and you don't have to poke a hole into the oil pan to run a oil return line.
I have plenty of ATI equipped cars in my project car section of my website. Bob
Old 09-25-2005, 12:13 PM
Got Me SOM's Avatar
cause he knows Vortec's better.
Old 09-25-2005, 12:30 PM
BLk01SS's Avatar
lol, actually I can buy a Vortech kit that's practically brand new for 3k. Are the Vortech's louder than the Procharger? I know on your vid Got Me SOM, it sounds really loud.
Old 09-25-2005, 12:34 PM
Got Me SOM's Avatar
mine's hella loud, lol. ATI's are much quieter than the Vortech's. I like it like that.
Old 09-25-2005, 12:41 PM
BLk01SS's Avatar
cool, I saw your car at Fbody Gathering a couple years ago. Sweet ride man. I may go to it this year, if I have time. I may get this kit and put it on. I just hate to cut the hood on this car. Is there any way the aftercooler can be modified so you don't have to cut the hood?
Old 09-25-2005, 12:43 PM
Got Me SOM's Avatar
oh really cool man. no there is no way of modifyiing it. if you get the underside painted it'll be unnoticeable.
i look forward to going there again, this time I want first place! Car should look a little different next time around.
Old 09-25-2005, 10:03 PM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
mines loud check out in sig
Quick Reply: Do you have to cut the hood for a Vortech aftercooled S/C??
