how to delay a shot on an M6 till 3rd
i would like to find out a way to delay the nitrous till i get to 3rd gear if possible without an expensive delay box i am not sure i have heard something about a bmn window switch that has a 1st gear lock out but i want one with a 2nd lock out to so i dont spray till i hit 3rd (dont want to shell the stock rear end) so do you guys have anything that might help me with this i will be instaling a 100 shot (wet) so i dont want it sprayin in 1st or 2nd untill i get a good rear end to hold it, Any input greatly apreciated thanks in advance
ur not going to "shell shock" the rear end unless u run a big shot +slicks...big shot like 200+. u'll be fine on street tires (DRs)and 100-150 hittin it in 2nd, I do.
u can always mount a micro switch on ur shifter so when u throw it in 3rd it turns on...u'd need one for 4th too.
so you think i will be ok sprayin in 2nd but what about traction i cant hook right now(i will have better tires by the time im sprayin like some nitto 285's cant hook the 275's i got right now in 2nd maybee with lower tire psi and a john force burnout i can hook it in 2nd) so the bmn window swithch with the first gear lockout how does this lockout work
I have a Jacobs N20 Mastermind and love it. It doesn't have different settings for each gear but it does allow you to bring the N2O in slowly. It works by fluttering the solenoids, so it's kind of hard on noids, but its worth it IMO.
If that's not an option, a WOT switch or other micro-switch inside the console would probably work. Like Screamin_Z said, you'll need one for 4th gear too.
I spray my 150shot in first gear and through 4th with no problems...stock rear on nittos. like screamin Z allready said, you'll only grenade the stock rear if you go all out with full slicks.
you can use the reverse of what someone allready said...use the micro switches to turn the nitrous off in 1st and 2nd gears..but you should use it in all your gears...by the time you get to 3rd gear your race will be half over. ;D
Originally Posted by 02SOMWS6
your going with a 100 shot so why not get a timming tuner so you can retard your timming and put a timed delay when the NOS hits. You shouldn't spray without retarding your timming
If all you want to do is moly spray it in third on then the cheapest way is to get a WOT switch and then put the activation switch in the ashtray like mine and when you shift to third flip the switch. Thats what I do.
