Fueling & Injection - Stock fuel pressure?
Whats the stock fuel pressure on a 98?
Matt@HSW
09-23-2005, 05:10 PM
Usually around 57 - 58 ish psi.
matt
How big injectors is possible to run with stock pump?
oange ss
09-24-2005, 02:14 PM
hp is the limiting factor on a stock pump not injector size
But there have to be a limit to the injector size right? When the pump can run them at 100% anymore....
oange ss
09-26-2005, 12:05 PM
not really, pump has nothing to do with injector size, the pump is there to meet the fuel consumption of the engine , the VCM controls injector duty cycle depending on fueling needs and of course fueling needs can surpass the safe operating limit for injector size
hawaiiboysz
09-27-2005, 12:53 PM
So there is no need to upgrade the pump then? Just injectors So when would you need a pump?
oange ss
09-27-2005, 01:36 PM
an upgraded pump is always a good idea, but you really wont need one till around 450 rwhp, the 01-02 injectors are good for about the same power range, the 98-00 cars will need to upgrade injectors around 400-420 rwhp
slmdLS1
10-24-2005, 05:44 PM
matt
44psi too low or is that "within a safe range" ?
oange ss
10-24-2005, 06:24 PM
too low
Matt@HSW
10-25-2005, 11:54 AM
Too low.
Matt
slmdLS1
10-29-2005, 06:25 PM
got it up to 58psi constant.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
