What cam for a 408 in my heavy ass truck?
Tin Foil Hat Wearin' Fool
What cam for a 408 in my heavy *** truck?
I will be putting a forged 408 in my truck in the next month or so after I get all the parts together and I dont realyl know where to start on choosing a cam. There arent many truck guys running 408's so I figured I would have a better chance of getting a good recommendation over here. I will be spraying on this motor too so I need something that will react decently well with the nitrous on. I have all the supporting mods in my sig. I want something with a nice lopey idle and somethin gthat is going to give me good midrange and have good power when the converter is locked so it doesnt feel like the motor is lugging down all the time.
Thanks
Thanks
Originally Posted by BigBlockChev572
MS3 Magic Stick
Ill look into that cam and findout what the specs are on it.
225/225 i too small Im looking for something in th emid to low 230 range on a 112lsa or so. I want lope too and that cam would be swallowed whole by a 408. If I was going to go with that I would just keep my cam that I have now. Second choice? Or I could jsut say f**k it and put a t-rex in it.
When you all make cam recommendations could you put the brand name and specs I am not familiar with the f-body cam sand their specs that are associated with the names. Ill look up that G5X2.
237/242, .603"/.609", 113 LSA It's pretty much the equivileant(sp?) of the T-rex but on a better LSA to help idle. But with a 408 a T-rex is somewhat mild so that'd be a good choice too.
Philip S.
Why are you asking for advice on for your truck on a car site? MS3 is
Philip S.
Philip S.
The only problem is that Im afraid of going to big and the engine not making enough power when the tc is locked and Im cruising down the highway. I like the specs on the ms3.
Philip S.
A 408, because of it's CI is naturally going to create low down torque, so that really shouldn't factor in your equation and the power points on those cams will be lowered with the extra CI, I think it'd be a good choice.
Philip S.
Philip S.
If people are putting T-rex's and MS3s in a 346ci, you'll be fine with your 408 motor.
Philip S.
Philip S.
Yes but you foget I am carrying around 2000 more punds than them too. Makes a hell of alot of difference. That MS3 cam sounds pretty good. Do you ahve a link to where I can buy one did a quick search and didnt come up with anything. All off them say it is a 225/225 cam.
Another problem is I do tow 6000 punds or so occasionally so I would ike to have something decently powerful down low so it doesnt bog down all the time but if need be I can just get my buddy with a cummins to pull the trailer I guess. The MS3 should have a good idle and I think Allen can handle tuning it. Anybody else got nay suggestions.
Im not so much worried about take off power Im tlakign about when the tc is locked up and I am cruising around town or on the highway and I am in the lower rpm ranges and pushing 5400#'s
Yes but you foget I am carrying around 2000 more punds than them top.
I know what you drive!! GEEZE! It'd help too if you got rid of that tool box...
Philip S.
Cant thats where the extra kick is stored. Sub boxes are in the way for under the rear seat mounting of it.
Philip S.
Im thinkin 225-250 shot. The first stage will be my ny-trex kit with a 150 wet shot then a second stage dry shot with 75-100. I will spray 150 out of the hole and then when I hit second gear turn the second stage on. I am going to run a window switch so I dont fry my itty bitty 60e. It has 2 grand of hard parts in it so Im hoping it will hold up fine. Im hoping for 500hp on motor alone and traction will only be the push of a button away.
