Lowered fan temps - now they stay on 3-4 mins after its shut off
I had my fan temps lowered some because it was still running hot in stop and go traffic w/the 160 and the temps lowered a lil, so they are slightly lower now, and now after it gets to 180-90ish after i shut it off the fans continue to run for about 4 more mins, is this a problem? why dont they shut off right away?
LS1TECH Sponsor
depends on how the tuner set it up...i usually ask the person if they want them to stay on...mainly a track purpose thing...kinda defeats the need for a fan switch. Its in the programming and for the most part is perfectly normal...if you dont like it go back to the tuner & have them set the turn off temp higher & you'll be set.
LS1TECH Sponsor
Originally Posted by slow
You don't want to adjust the temp for the fans to remain running with teh vehicle off, unless you really want that adjusted. I normally just lower the normal fan temps.
Ryan
Ryan
