Drag Racing Tech - how to get the stock steering wheel off?
liftin'em on nittos
09-25-2005, 07:30 PM
i was sanding on my cage today and was thinking about taking the steering wheel off to easier get in and out of the car with the 10pt in it. i have the grant quick release hub and a grant wheel...i don't want to mess the stock wheel up if possible.
Matt D
09-25-2005, 07:46 PM
take off the bolts going into it, then the airbag, then use a puller. it should come off nice and clean with a steering wheel puller.
liftin'em on nittos
09-25-2005, 07:49 PM
ok, i was worried about the air bag more than anything...sounds easy enough.
DMH Fabrication
09-25-2005, 08:15 PM
yeah the air bag uses a 4 torx head bolts and then there is a big nut you pull off that holds the wheel on. Then put the puller on and your good to go.
mongse
09-25-2005, 08:58 PM
Don't forget to trim back the little white horn button too. :)
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
